17 years agoDMA controller in SOP buidler question
I'm using SOPC Builder to integrate into my system v8.0 sp1. * A new DSP builder component with 2 Avalon Slave (Read & write Fifo's) * 2 DMA controller (Avalon master) to load data to the dsp...
17 years agoOkay. New in 8.0 there is a script called sopc-create-header-files. If you run this script on your SOPC system (.sopcinfo), it will supposedly create header files for your components that you can include in your project. You would run this from the NIOS II Command Shell.
Try it out. Jake
