17 years agoDivision Approximation In Fm Demodulator
i am a post-graduate student at the university of ioannina greece "physics department". my thesis subject has to do about an implement of sdr receiver and demodulation of fm signal. i already have im...
17 years agoI was referring to the above discussion about omitting the division, if the signal magnitude is constant. Generally it isn't constant. Automatic scaling still leaves an 1:2 amplitude variation. So if you require the demodulated signal to be scaled correctly, you either should use the division or somethink like ADC. I don't want to suggest a particular implementation, cause a suitable design depends on the overall system structure.
