12 years agoDistributing low frequency clock with Cyclone V FPGA
I am trying to use part of the Cyclone FPGA as a clock distribution chip. There is one input clock to FPGA (about 5 MHz), and I would like to distribute it into 4 outputs to four external chips. ...
12 years agoI would use the dedicated PLL's and their dedicated outputs for this task. The problem however, is only some of the PLL's have dedicated outputs.
And they only have 2 outputs each. The timing will be much better since they will have dedicated routing. 5 MHz is the low end of the acceptable input clock frequency, so I would test do a test build to make sure the PLL's don't give you any surprises. The Cyclone V's also support a zero delay using external feedback, so that should improve your phase alingment. http://www.altera.com/literature/hb/cyclone-v/cv_52004.pdf describes the PLL's and their capabilities in more detail. Pete
