FFmine
2 years agoDiscrepancies between datasheets and technical documentation regarding FPGA configuration.
About Arria V data sheet https://www.intel.com/content/www/us/en/docs/programmable/683022/current/active-serial-as-configuration-timing.html Note 105 is as follows. 105 To evaluate the data setup...
FFmine
2 years agoThanks for your reply
I think so too.
Your opinion has gave me confidence in my thinking.
But tDSU and tSU has different value in Arria V data sheet.
tSU value is 1.5nsec at AS configureation section and tDSU value is 5.5nsec at PS configureation section.
And, these paramaters has diffarent memo as follows.
tSU : Data setup time before the falling edge on DCLK
tDSU: DATA[] setup time before rising edge on DCLK
I realized the probrem is an explanation method for tSU is tDSU in AS configurasion section.
Thank you for your help.
