12 years agoDigitize RGB video using DE0-Nano
Hi all, I'm building a 15Khz RGB to VGA converter using the DE0-Nano, to be used with old computers from the 80's. I know there are some boards in the market like GBS8200 but I'm not happy with...
12 years agohere my code. Look that I force the HSYNC to match the end of the line: 655 (for the sync) and the vsync to match the last scanline 262.5. CLOCK_50 = 25.17Mhz and CLOCK_25=12.58Mhz. I got less jitter using 25Mhz for the horizontal counter:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity vgaoutput is generic( front_porch : integer := 100; top_border : integer := 35 ); port(CLOCK_50 : in std_logic; CLOCK_25 : in std_logic; VSYNC_IN : in std_logic; HSYNC_IN : in std_logic; RGB_IN : in unsigned(2 downto 0); -- r, g, b VGA_OUT : out unsigned(4 downto 0) -- r, g, b, hsync, vsync ); end vgaoutput; architecture behavioral of vgaoutput is signal hcount : unsigned(9 downto 0) := (others => '0'); signal vcount : unsigned(9 downto 0) := (others => '0'); signal pixelcolor : unsigned(2 downto 0) := "000"; signal videoon, videov, videoh, hsync, vsync : std_ulogic := '0'; signal reset : std_ulogic := '1'; signal vblank : std_ulogic := '1'; signal hblank : std_ulogic := '1'; signal hcount_in : unsigned(10 downto 0) := (others => '0'); signal vcount_in : unsigned(9 downto 0) := (others => '0'); type line_memory_t is array (0 to 640*204-1) of unsigned(2 downto 0); shared variable line_memory : line_memory_t; begin ----------------------------------------- -- RGB INPUT ----------------------------------------- vsyncin: process(CLOCK_25) begin if (rising_edge(CLOCK_25)) then vblank <= '1'; if (VSYNC_IN = '1' and vcount_in >= 262 and hcount_in(10 downto 1) >= 399) then vblank <= '0'; end if; end if; end process; hsyncin: process(CLOCK_50) begin if (rising_edge(CLOCK_50)) then hblank <= '1'; if (HSYNC_IN = '1' and hcount_in(10 downto 1) >= 655) then hblank <= '0'; end if; end if; end process; hcounter_in: process(CLOCK_50) begin if (rising_edge(CLOCK_50)) then if hblank = '0' then hcount_in <= (others => '0'); else hcount_in <= hcount_in + 1; end if; end if; end process; vcounter_in: process (CLOCK_25) begin if(rising_edge(CLOCK_25)) then if vblank = '0' then vcount_in <= (others => '0'); elsif hblank = '0' then vcount_in <= vcount_in + 1; end if; end if; end process; pixel_in: process(CLOCK_25) variable addr: integer range 0 to 153600; variable row, col: integer range 0 to 153600; begin if (rising_edge(CLOCK_25)) then if (hcount_in(10 downto 1) >= front_porch and hcount_in(10 downto 1) < front_porch+640 and vcount_in >= top_border and vcount_in < top_border+204) then col := to_integer(hcount_in(10 downto 1)) - front_porch; row := to_integer(vcount_in) - top_border; addr := (row * 640) + col; line_memory(addr) := RGB_IN; end if; end if; end process; ----------------------------------------- -- VGA OUTPUT ----------------------------------------- vcounter: process (CLOCK_50, hcount) --, vblank) begin if(rising_edge(CLOCK_50)) then if hcount = 799 then vcount <= vcount + 1; end if; if vcount = 525 then vcount <= (others => '0'); end if; end if; end process; v_sync: process(CLOCK_50, vcount) begin if(rising_edge(CLOCK_50)) then vsync <= '1'; if (vcount <= 492 and vcount >= 490) then vsync <= '0'; end if; end if; end process; hcounter: process (CLOCK_50) begin if (rising_edge(CLOCK_50)) then hcount <= hcount + 1; if hcount=799 then hcount <= (others => '0'); end if; end if; end process; h_sync: process (CLOCK_50, hcount) begin if (rising_edge(CLOCK_50)) then hsync <= '1'; if (hcount <= 752 and hcount >= 655) then hsync <= '0'; end if; end if; end process; pixel_out: process (CLOCK_50) variable addr: integer range 0 to 153600; variable row, col: integer range 0 to 153600; begin if (rising_edge(CLOCK_50)) then if (hcount < 640 and vcount < 408) then col := to_integer(hcount); row := to_integer(vcount(9 downto 1)); addr := (row * 640) + col; pixelcolor(2 downto 0) <= line_memory(addr)(2 downto 0); end if; end if; end process; process (vcount) begin videov <= '1'; if vcount > 479 then videov <= '0'; end if; end process; process (hcount) begin videoh <= '1'; if hcount > 639 then videoh <= '0'; end if; end process; videoon <= videoh and videov; VGA_OUT(4 downto 2) <= pixelcolor and videoon&videoon&videoon; VGA_OUT(1 downto 0) <= hsync & vsync; end behavioral;
