12 years agoDigitize RGB video using DE0-Nano
Hi all, I'm building a 15Khz RGB to VGA converter using the DE0-Nano, to be used with old computers from the 80's. I know there are some boards in the market like GBS8200 but I'm not happy with...
12 years ago --- Quote Start --- I assume (with your current implementation) you are adjusting the outgoing data, by a full clock cycle, every time you detect a 'change' to the incoming HSYNC pulse timing. --- Quote End --- I will copy the full code here later when I get home. But basically I have a framebuffer and I control the incoming hcount and vcount by waiting the hsync and vsync (they are positive pulses in this case) like process(CLOCK_25) begin if (rising_edge(CLOCK_25)) then hblank <= '1'; if (HSYNC_IN = '1' and hcount >= 655) then hblank <= '0'; end if; end if; end process; process(CLOCK_25) begin if (rising_edge(CLOCK_25)) then if (hblank = '0') then hcount <= 0; else hcount <= hcount + 1; end if; end if; end process; Being CLOCK_25 the 12Mhz clock. Then I use hcount together the vcount to calculate the offset in the pixel array to store it. The VGA output has it's own 25Mhz clock and since it's buffered, it doesn't rely on the incoming hsync, vsync. It just pumps out whatever is in the buffer.
