9 years ago
digital watch
hello every one i have design digital watch second , minute , hour after i execute the code the counter second and minute counter ok work . for 0 to 59 but hour counter form 0 to 99 ?
i have question hour about how make counter to 0 to 24 or 0 to 12 ?
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY SEQ_COUNTER IS
    PORT
            CLK_1, RST            : IN STD_LOGIC;
            CLK_2                    : BUFFER STD_LOGIC;
            SEC_1, SEC_2        : BUFFER INTEGER RANGE 0 TO 9;
            MIN_1, MIN_2        : BUFFER INTEGER RANGE 0 TO 9;
            HR_1, HR_2            : BUFFER INTEGER RANGE 0 TO 9;
            Q                        : BUFFER INTEGER RANGE 0 TO 9
END SEQ_COUNTER;
ARCHITECTURE SEQ_COUNTER OF SEQ_COUNTER IS
BEGIN
    PROCESS (CLK_1,RST)
    VARIABLE S1, S2, M1, M2, H1, H2    :INTEGER RANGE 0 TO 10;
    BEGIN
        IF ( RST ='0' ) THEN
            S1 :=0;
            S2 :=0;
            M1 :=0;
            M2 :=0;
            H1 :=0;
            H2 :=0;
            SEC_1 <=0;
            SEC_2 <=0;
            MIN_1 <=0;
            MIN_2 <=0;
            HR_1     <=0;
            HR_2     <=0;
            Q <=0;
        ELSIF ( CLK_1'EVENT AND CLK_1 ='1') THEN
            S1 := S1 +1;
            IF ( S1 = 10) THEN
                S1 :=0;
                SEC_1 <=0;
                S2 := S2 +1;
                IF ( S2 = 6) THEN
                    S2 :=0;
                    SEC_2 <=0;
                    M1 := M1 +1;
                    IF ( M1 = 10) THEN
                        M1 :=0;
                        MIN_1 <=0;
                        M2 := M2 +1;
                        IF ( M2 = 6) THEN
                            M2 :=0;
                            MIN_2 <=0;
                            H1 := H1 +1;
                            IF ( H1 = 10) THEN
                                H1 :=0;
                                HR_1 <=0;
                                H2 := H2 +1;
                                    IF ( H2 = 1 OR H1= 3 ) THEN
                                    H2 :=0;
                                    HR_2 <=0;
                                END IF;
                            END IF;
                        END IF;
                    END IF;
                END IF;
            END IF;
        END IF;
        SEC_1 <= S1;
        SEC_2 <= S2;
        MIN_1 <= M1;
        MIN_2 <= M2;
        HR_1     <= H1;
        HR_2     <= H2;
    END PROCESS;
END SEQ_COUNTER;
    --- Quote Start ---
    We all (or most of us) are doing this for fun in our own time, so sometimes we have other things to do, or are working on our own designs. It will help to get replies if you write what you have done and why instead of just dumping code and then expecting others to do your work for you. Having said that: if h1=10 it will never be 3, which you heck in the inner if statement or h1=3, so that idea doesn;t work. but why check on 10 and not 24, or use an extra if statement?
    --- Quote End ---
    ok good question if we change h1= 23 the will count over 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 in logic but in physical in board will show until 9 after 0 0 0 0 0 0 0 in board coz one 7 segment
    but my question is clear i understand the concept second and min but really confuse about hour coz h1=10 is right count 0 to 9 after that h2 = 2 count 0 to 2 result in board
    0 1 2 and it will rest to 0 start again will be like that 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
