16 years agoDiffrerential Pins topology
Hi I want to interface my FPGA to a DAC using LVDS Standard. The problem is, that the FPGA and DAC pins topologies are not the same. Each FPGA positive pin cannot be directly (physically) conne...
16 years agoIt's not exactly forbidden to use vias for a 400 MBps connection, you can use them even for GBit interfaces. Typically, longer differential traces are run in a screened inner layer, so you have at least a pair of vias at each end. They can be used to invert the polarity as well. But I agree, that you should avoid vias if possible. If you have only a short connection on the top layer, I would also invert the driving nets inside the FPGA, as rbugalho sugested.
