16 years agoDiffrerential Pins topology
Hi I want to interface my FPGA to a DAC using LVDS Standard. The problem is, that the FPGA and DAC pins topologies are not the same. Each FPGA positive pin cannot be directly (physically) conne...
16 years agoNegating signals is, AFAIK, the only solution.
It's possible that you come across some issues which may require a bit of care but nothing serious. For example, you can't invert the output of altddio_out block -- your have to to invert the inputs.
