Parkavi
4 years agoDifferent behavior of FPGA on power cycle-Cyclone v FPGA(custom board)
I have a design with Cyclone v transceiver native phy IP. Logic receive UART data and framing it with header, tailer and sending it to IP.IP send it serially to SFP fibre cable which is loopba...
Parkavi
4 years agoHi Aiman,
My problem got resolved.
1. In manual word aligner mode, i manually drive rx_walign port when i sent word align pattern. In this case ,the above null issue was resolved.
2.As i said before, in sync_sm mode i found corruption in data packets. That was resolved by setting rx word align pattern as 17C in IP configuration , enabled 8b/10b encoder and decoder ,driving tx_datak port from rx_syncstatus which is inverted and given.And transmitting BC to IP.
Thank you for your support!!!!
