Parkavi
4 years agoDifferent behavior of FPGA on power cycle-Cyclone v FPGA(custom board)
I have a design with Cyclone v transceiver native phy IP. Logic receive UART data and framing it with header, tailer and sending it to IP.IP send it serially to SFP fibre cable which is loopba...
NurAiman_M_Intel
4 years agoHi,
- Can you try to program by using the latest version of Quartus lite which is 21.1 to see if you get the same problem?
- Also, please try to create a simple design, convert into JIC and then program it. Then try to power cycle. Do you get the same problem?
Aiman
