19 years agoDifference between VCCIO and VREF?
hi,everyone. i just start to use fpga cycloneIII,and i have a question which may be easy to answer. Thank you. question :is it right that VCCIO just supply the power?for example,if i want...
18 years agoBe careful when using the VREF pins as fast I/O on the Cyclones, the VREF pins have a higher capacitance than the regular I/O pins.
