19 years agoDifference between VCCIO and VREF?
hi,everyone. i just start to use fpga cycloneIII,and i have a question which may be easy to answer. Thank you. question :is it right that VCCIO just supply the power?for example,if i want...
18 years ago --- Quote Start --- If you don't use SSTL/HSTL, VREF pins can be used as normal I/Os. --- Quote End --- Make sure you check the device handbook before doing this - I don't know about older devices, but the Stratix IV specifically states that if VREF pins are not used for voltage referencing, they cannot be used as generic I/O (Vol.1, 6-54)
