17 years agoDFF Clock Polarity & Other signal polarities
Hi all, I'm relatively new to Quartus, but have used Altera and their other tools long ago. Currently, I'm using Quartus II web edition using Block/Schematic entry building a MAX II device. ...
17 years ago --- Quote Start --- Hi all, I'm relatively new to Quartus, but have used Altera and their other tools long ago. Currently, I'm using Quartus II web edition using Block/Schematic entry building a MAX II device. A question that always comes up is: What is the active-edge/polarity of the various parts of the LEs ? Namely, the flip-flop clocks. Also, what's the polarity of the tri-state control on the IOEs ? I guess a broader question would be, where does one find this low-level info on the specifics of the LEs ? A 2nd Question: When specifying, for example, a device-wide output enable in the Device and Pin Options, where/how is the pin assigned? Thanks for your help RW --- Quote End --- Hi, for detailed info's look into: http://www.altera.com/literature/hb/max2/max2_mii51002.pdf Kind regards GPK
