16 years agoDevice selection
Hello, I am looking for a simple glue logic solution that has about 4k D-flip flops. The glue logic just involve simple counters, shift registers, and combination logic. But I need very tigh...
16 years ago --- Quote Start --- Hello, I am looking for a simple glue logic solution that has about 4k D-flip flops. The glue logic just involve simple counters, shift registers, and combination logic. But I need very tight timing data for the logic such as setup time, hold time, etc. I found that the MAXII datasheet has very detail timing data, but the Cyclone FPGA datasheet does not show any detail. All I can see from its handbook is that it can go up to a few hundred MHZ. But the MAXII might not have enough gates for my purpose. I do not want to install any software on my PC until I am sure I want to go for a particular device. I look at other competitors web site and similar things happen. Most CPLD datasheet provides detail timing, but most FPGA datasheet is very vague on timing information. BR - Henry --- Quote End --- Hi Henry, the internal timings will not give you the answer your are looking for. The internal timings describe in my point of view only a theoretical speed, because the achievable clock speed depends more on your design. If you have e.g. a design with a lot of logical levels it will run very slow on every FPGA. Have a look to : http://www.altera.com/literature/hb/cyc3/cyc3_ciii52001.pdf In this document you will find at least some timings for the internal clock trees and a few other things. Kind regards GPK
