9 years agoDetect high impedance on the input pin
Hi to all, for my little project, I need to manage the output pin of any FPGA placing them at high impedance. This is not a problem, I can do it with MAX10 and Cyclone IV. However I would ...
9 years agoAn unconnected High Z Pin gives you only true or false to the internal logic. In order to get the High Z State you need some additional circuitry.
Some ideas:- connect you pin to VCCIO/2 with a 10k resistor and use a window comparator to detect this level. Maybe this is possible with differential LVDS inputs.
- use a external window comparator with 2 digital outputs to the FPGA
- connect your pin to another toggling pin with a 10k resistor and try to detect this frequency or pattern (eg: 1MHz)
- use a RC combination from your external signal to the FPGA bidir PIN and use short test pulses (with output enable) to charge/discharge the capacitor. The time constant is different depending on the external Level (0, Z, 1)
- use a RC combination from your external signal to the FPGA bidir PIN and use short test pulses (with output enable) to discharge the capacitor and a weak pullup to charge measure the time the pin needs to go high: short time: Pin is connected to "1" longer time: Pin is connected to "Z" never: Pin is connected to "0"
