15 years agoDesign Size and the timing accuracy
Dear Sir, I've met one problem. It is about the design size and timing accuracy. If I have a design which used up the FPGA 95% or above LEs, is it going to have some I/Os having worse tim...
15 years agoDear GPK,
Thanks for your explaination. The problem was found in a project which uses a FPGA MAXII micro to drive an external a LCM through an I2C interface designed via the I/Os. I've tried several times. When the design size larger, the timing of output signal is going to be wrong. For some test pins, even the outputs are incorrect. I feel strange. Thus, I think the problems were caused by the limited resource in the FPGA. :) Regards, Peter Chang
