15 years agoDesign Size and the timing accuracy
Dear Sir, I've met one problem. It is about the design size and timing accuracy. If I have a design which used up the FPGA 95% or above LEs, is it going to have some I/Os having worse tim...
15 years ago --- Quote Start --- Dear GPK, Thanks for your comment. I believe SDC is important for the timing constraints. However, is it possible that the requirements of my design are over that FPGA could provide in timing, especially while the available LEs are less. Regards, Peter Chang --- Quote End --- Hi Peter, of course it could be more difficult for Quartus to implement your design when the uitilization is high. You mentioned that you have mainly I/O timing problems. Can you explain it a little bit more ? Maybe I would help when you register your inputs and outputs by using the registers in the I/O cells. Kind regards GPK
