15 years agoDesign Size and the timing accuracy
Dear Sir, I've met one problem. It is about the design size and timing accuracy. If I have a design which used up the FPGA 95% or above LEs, is it going to have some I/Os having worse tim...
15 years ago --- Quote Start --- Dear Sir, I've met one problem. It is about the design size and timing accuracy. If I have a design which used up the FPGA 95% or above LEs, is it going to have some I/Os having worse timing which may violate the requirements? Suppose, the answer is 'yes', because it is limited by the available resources. What I am going to ask is how to efficiently manage the available LEs to meet the requirements? Is setting timing constraints in SDC file a goody way? In a case of no improvement, after changing the contraints, does it mean the available resource and path is used up? Thank you in advance. Regards, Peter Chang --- Quote End --- HI Peter, at first you need a proper SDC file. You have at least to constrain you Inputs, Outputs and clocks. This is important, because the constrains are used by Quartus for implementation of your design. Kind regards GPK
