Design security key programming gone wrong!
May I know if the board can still be programmed with unencrypted bitstream?
I do not have any information as what might be happen as there is no way for us to know what is the key programmed to the device.
- SEbbert5 years ago
Hi John,
thanks for the quick reply.
Yes, the FPGA runs unencrypted bitstreams. It just doesn't run with encrypted bitstreams that match the programmed non-volatile design security key.
My issue step by step:
- The Cyclone V GT DevKit is setup to use the Active Serial configuration scheme, booting from the EPCQ256 device -> MAX V is programmed with the correct .pof file and MSEL dipswitches are set accordingly.
- I program a non-volatile design security with an EthernetBlaster II using the same .ekp file as always.
- I program a .jic file to the EPCQ256 that was encrypted with the key used in the ekp file.
- The FPGA does not configure successfully and the Load-LED is flickering
- The FPGA configures successfully if I program an unencrypted .jic file to the EPCQ256
Is there really no way at all to find out what key was actually programmed? Maybe I can return the Board to you for finding out the actual key and compare it to the one in the ekp file?
Best regards
