12 years agoDesign of an FPGA based bit error rate tester
Hello. I am looking into making an FPGA based BERT for some lab testing based on this article http://www.physics.smu.edu/web/research/preprints/smu-hep-11-14.pdf I found on the web. I am not an FPGA ...
12 years ago --- Quote Start --- My application would be bit error rate testing of what are essentially SFP / SFP+ modules operating from 1.25Gbps to 10.3125Gbps. I need an electrical transmit and receive channel (SMA connections), an optical transmit and receive channel (SFP module), and a trigger output (SMA connection) for a scope. I certainly wouldn't argue with the option of having more I/O channels for future expansion but that is all I need at the moment. --- Quote End --- The need for 10.3125Gbps pushes you into the higher-end and therefore higher cost devices. To test SFP/SFP+ modules at 10Gbps you want a board with one or more SFP/SFP+ connectors, so that your signals are not distorted by adapter/connector transitions. To test a transceiver via SMA connectors, you do not need the SMA connectors on the PCB, you just need an SFP/SFP+ to SMA breakout cable, eg., I use QSFP+ breakout cables from Elpeus (yes, they are $600 each, but your time is worth money too ...) http://www.elpeus.com/categories/sma-test-cables.html I do not have a kit with SFP/SFP+ connectors. I am using a kit with FMC connectors and an FMC-to-QSFP+ adapter board (not an ideal setup for 10Gbps). Browsing through the list of Altera kits http://www.altera.com/products/devkits/kit-dev_platforms.jsp I see ... http://www.altera.com/products/devkits/altera/kit-stratix-v-dsp.html http://www.altera.com/products/devkits/altera/kit-sv-gx-host.html * both have a QSFP+ connector (you can use a QSFP-to-SFP breakout cable) http://www.altera.com/products/devkits/altera/kit-sv-gt-si.html http://www.altera.com/products/devkits/altera/kit-transceiver-si-stratix-v.html http://www.altera.com/products/devkits/altera/kit-stratix-v-gx-100g.html * transceivers and SMA connectors * I tend to avoid these boards as they are expensive and not too useful for anything but looking at transceivers (no DDR etc). http://www.nallatech.com/pci-express-fpga-cards/pcie-385n-altera-stratix-v-fpga-computing-card.html http://gidel.com/procev.html * SFP/SFP+ ports http://www.bittware.com/products-services-fpga-cots-hardware/a5-pcie-l-a5pl http://www.bittware.com/products-services-fpga-cots-hardware/s5-pcie-hq http://www.bittware.com/products-services-fpga-cots-hardware/s5-pcie-ds * QSFP+ ports * Bitware has several other products like this too http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=13&no=&~123 * Terasic have several boards with QSFP+ or SFP+ connectors too Browse through these options and check out pricing. Terasic and Bittware make nice hardware and have good support. If you are considering "software development" using your FPGA, then you might want to consider buying a board that is already supported by Altera's OpenCL (you can do a little more research to check which boards are supported). Cheers, Dave
