10 years agoDelaying output of a module to close timing
I've created a module where two numbers are multiplied and the output is provided in a number of clock cycles. However, the output of the module (pdt1_out) is failing timing in that the setup slack ...
10 years agoThanks, kaz. Yes, that sums up nicely what I've also found regarding the use of multicycle paths for this particular design.
