15 years agoDelaying 1 cycle in my clock
I am new to the CPLD design. Can I use a buffer to delay my clock just for one cycle then in Quartus II's megafuction? Or is there a clock delay megafuntion in Quartus II library?
15 years agoThe image you have drawn is incorrect. If you have a signal that is a pulse relative to a clock, then it will last for a full clock period, not half a period as you have shown.
Given an external signal 'd', you can delay it one clock to give an output 'q' using a register, eg. in VHDL process(clk) begin if rising_edge(clk) then q <= d; end if; end process; If 'd' is pulsed, then 'q' will pulse one clock later. In either case, the clk signal is not delayed, it is the signal that is delayed by one clock. Cheers, Dave
