16 years agodelayed pulse generator
hello , i must do a delayed circuit pulse generator.(i can set delay and width of pulse). My code works fine, but quartusII make a warning (complex event). can i do this circuit in another mode? ...
16 years agoYou can't initialize an input as in:
reg[11:0] Start=0; reg[12:0] Stop=0; reg[11:0] StartREF=10; reg[12:0] StopREF=4700; You just need an enabled counter. The counter starts counting the clock cycles when Start goes to '1' when the counter reaches the delay value (depending on the required delay) then outPulse is asserted. module GateGENERATORASSER(clk,start,outPulse,delay,reset); input reset,clk,start input [7:0] delay; // Maximum 255 clock cycles of delay output outPulse; reg [7:0] count; always @(posedge clk) begin if (reset) count<=8'h00 else if (start) count<=count+1; else count<=0; end assign outPulse= (count>delay) ? 1'b1 : 1'b0; endmodule This leaves with a precision that is no lower than the clock period. And works if start doesn't do strange things.
