17 years agodefining pinout in Cyclone3 to EPCS
hi, i'm using in Cyclone 3. In Quartus 8 manual is written "If you use a Cyclone3 device, you must connect wires to EPCS device mannually". I defined in my top entity 4 signals to epcs controller,...
17 years agoI found the solution site of Altera:
solution In Cyclone® III devices, the EPCS controller does not automatically assign its output pins to the dedicated configuration pins on the FPGA. Instead, the output pins are exported to the top level design, giving users the flexibility to connect to any EPCS devices. Therefore, in order to use the EPCS Configuration Controller the pins must be assigned manually, and the following settings must be made the Quartus® II software. Please follow these steps:- Choose settings from the assignments menu
- Click device and pin options from the Device category
- Click dual-purpose pins and then make the following changes:
