17 years agodefining pinout in Cyclone3 to EPCS
hi, i'm using in Cyclone 3. In Quartus 8 manual is written "If you use a Cyclone3 device, you must connect wires to EPCS device mannually". I defined in my top entity 4 signals to epcs controller,...
17 years agoI guess, you refering to this statement in QuartusHandbook
--- Quote Start --- Board-Level Design for an EPCS Device You must connect the EPCS device to the FPGA as described in the Altera Configuration Handbook. No other connections are necessary. --- Quote End --- It's about hardware design, not Quartus settings. An AS configuration device uses dedicated resources and needs no entries in Assignment Editor or Pin Planner. Just select AS configuration scheme in Device Options.
