HBhat2
Contributor
7 years agoDefault Termination of Stratix 10 Single Ended IO
Hi, What will be the default Termination resistance of Stratix 10 FPGA GPIO when configured as i) Input ii) output? With Regards, HPB
- 7 years agoHello , For the single ended IO standard such as LVCMOS or LVTTL internal termination resistor is not supported . From the table 9 in the below link shows it supported channel. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-gpio.pdf Also refer Table 4 and Table 5 supported programmable feature and default state for each IO stand's. Thank you , Regards, Sree
SreekumarR_G_Intel
7 years agoHello ,
Thank you ,
Sree
- HBhat27 years ago
Contributor
Thank you for your reply.
With regards,
HPB
