13 years agoDefault latched outputs values
Hi guys, I'm working on a multi deck elevator controller using niosII and i thought it's better to relief the processor from handling the displays (floors + car motors display : up,down,1,2...etc ...
13 years agothx kaz, i liked the little trick you mentioned; u didn't actually force the output to a certain value AT power up but still you managed to make it looks like it is :). i was wondering if some setting exists to initialize the output of a certain block in any design (not even in VHDL). anyway, here is my edition based on your suggestion:
signal initial,rst : std_logic := '0'; -- used for initialization begin rst <= reset_n and initial; process (clk) begin if rising_edge(clk) then initial <='1'; end if; end process;i then used rst later instead of reset_n for the whole code the way you mentioned and it works fine. well i guess you're not a guru for nothing :p thanks a lot bro ;) FvM, i couldn't really see the problem you're refering to, if you're talking about encoding the floor sensors not to read 1 and 2 in going from 0 to 3 than it's done. an encoder is instantiated on the top level for this purpose together with the keypads' inputs. i hope that's the point you're talking about, let me know if i'm wrong. merci a toi :cool:
