Dedicated SERDES usage for ADC LTC2387-18 with Cyclone V?
- 6 years ago
Hi Vadim
I hope I understand your situation correctly.
Yes, the ALTLVDS_RX is tied with a PLL. If your design has limitation towards the PLL lock time on the spec, then you have to create logics to implement the receiver.
Unfortunately we don't have sample reference design for this logic creation. For recommendation, we can make use of shift register and parallel register to construct the LVDS receiver.
We shall always refer to "Design Guidelines" mentioned in the doc below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc/cyc_c51009.pdf
Eng Wei
Hi Vadim
Eng Wei
Hi Eng Wei!
Thank you very much for your answer.
Vadim
- EngWei_O_Intel6 years ago
Hi Vadim
Eng Wei
