Dedicated SERDES usage for ADC LTC2387-18 with Cyclone V?
- 6 years ago
Hi Vadim
I hope I understand your situation correctly.
Yes, the ALTLVDS_RX is tied with a PLL. If your design has limitation towards the PLL lock time on the spec, then you have to create logics to implement the receiver.
Unfortunately we don't have sample reference design for this logic creation. For recommendation, we can make use of shift register and parallel register to construct the LVDS receiver.
We shall always refer to "Design Guidelines" mentioned in the doc below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc/cyc_c51009.pdf
Eng Wei
Thanks Vadim for your inquiry. Allow me some time to go through your design question and get back to you.
Eng Wei
- EngWei_O_Intel6 years ago
Hi Vadim
Eng Wei
- VOS6 years ago
Hi Eng Wei!
Thank you very much for your answer.
Vadim
Hi Vadim
Eng Wei
- IDeyn6 years ago
Contributor
Hi all!
Well, in case the PLL is tied with ALTLVDS_RX core, I suppose that maybe we could use pfdena signal for locking the DCO and so on, but in general we should create receiver logic from LEs.
Ivan
