13 years agoDE5-NET JTAG Configuration Problem
Hi all, I tried to program the Stratix V FPGA on the DE5-NET board through the UBS Blaster cable. Each time, the programmer goes up to somewhere between 95% - 98% and fail. The error i get is ...
13 years agoYou can turn down the USB-Blaster II JTAG clock speed with this command:
jtagconfig --setparam <cable name> JtagClock <speed> The cable can't do every cable speed but it won't run faster than you specify, use --getparam to read the current value. The fastest three speeds it can run at 6M, 16M and 24M (the default).
