13 years agoDE5-NET JTAG Configuration Problem
Hi all, I tried to program the Stratix V FPGA on the DE5-NET board through the UBS Blaster cable. Each time, the programmer goes up to somewhere between 95% - 98% and fail. The error i get is ...
13 years agoHi Wombat. I tried to download demo .sof files as well and got the same error. So it seems likely that the data is getting corrupted on the way as you said.
I'm using the on-board USB blaster with the cable. I tried using different USB cables, just in case, but it didn't change anything. I also tried on different computers to see if it was a driver compatibility issue, but it was the same result each time.
