10 years agoDE2I150 - Nios compilation error
Hello, I am a newbie in using nios. I am trying to store an image which is sdcard onto a sdram. My c code has this function: IOWR_16DIRECT(SDRAM_BASE,(((i+80)*640+(j))-40),pixel) . When I compi...
10 years agoPerhaps not the better solution, but you can make a serach on all files of the project and all files of Altera's instalation, seeking the specific keyword "IOWR_16DIRECT" within each file. After findind, if occurs more than just one, you can select the one which makes more sense in regar to what compiler or current project you are working, and manually add it with the "INCLUDE" directive at the header of your code.
