17 years agoDE2_TV problem
In the file of itu_r656_decoder ,what's the affection of " if ((h< 51) || (h > 771)) " and " if ((h< 41) || (h > 781)) "?
And " Vde_counter >31 and Vde_counter <511",why must the Vde_counter larger than 31 ? `define sync 8'd101 module itu_r656_decoder ( input CLOCK, input [7:0]TD_D, input TD_HS, input TD_VS, input SW0, input SW1, output [7:0]Y, output [7:0]Cb, output [7:0]Cr, output reg HSx2, output VSx1, output reg Ypix_clock, output blank ); assign VSx1=TD_VS; /////// FF 00 00 SAV(EAV) ////// reg[7:0]R1,R2,R3; reg[7:0]RR1,RR2,RR3; wire Y_check=( (R3==8'hff) && (R2==8'h00) && (R1==8'h00) )?1:0; always @(posedge CLOCK) begin RR1=TD_D; RR2=R1; RR3=R2; end always @(negedge CLOCK) begin R1=RR1; R2=RR2; R3=RR3; end /////decode SAV(EAV) //// reg START,Field; always @(posedge CLOCK) begin if (Y_check==1) begin START=~TD_D[4]; Field= TD_D[6]; end end //////YUV4:2:2 to YUV4:4:4///// reg [7:0]YY; reg [7:0]CCb,Cbb; reg [7:0]CCr,Crr; reg [1:0]COUNTER; always @(posedge CLOCK) begin if (!START) COUNTER=0; else COUNTER=COUNTER+1; end always @(posedge CLOCK) begin case (COUNTER) 0:begin Cbb=TD_D; Ypix_clock =0;end 1:begin YY =TD_D;CCr=Crr;CCb=Cbb; Ypix_clock =1;end 2:begin Crr=TD_D; Ypix_clock =0;end 3:begin YY =TD_D;CCr=Crr;CCb=Cbb; Ypix_clock =1;end endcase end ///// auto-counting H length //// reg [10:0]H_COUNTER; reg [10:0]RH_COUNTER; always @(posedge CLOCK) begin if (TD_HS) H_COUNTER=0; else H_COUNTER=H_COUNTER+1; end always @(posedge TD_HS) begin RH_COUNTER=H_COUNTER; end /////to generate HSx2//// always @(posedge CLOCK) begin if ( ((H_COUNTER >= 0) && (H_COUNTER < `sync)) || ((H_COUNTER >= RH_COUNTER[10:1]) && (H_COUNTER < (RH_COUNTER[10:1]+`sync+1))) ) HSx2=0; else HSx2=1; end /////H blank for HSx2///// reg [10:0]h; reg h_tr; reg h_tr_h; always @(posedge CLOCK) begin if(!HSx2) h=0; else h=h+1; end always @(posedge CLOCK) begin if ((h< 51) || (h > 771)) h_tr=0; else h_tr=1; end always @(posedge CLOCK) begin if ((h< 41) || (h > 781)) h_tr_h=0; else h_tr_h=1; end /////V blank for HSx2////// reg[10:0]Vde_counter; always@(posedge HSx2)begin if (TD_VS==0) Vde_counter=0; else Vde_counter=Vde_counter+1; end ///v-h blank output// wire vde=((Vde_counter > 31) && (Vde_counter < 511)) ? 1:0;//480 wire blank_h = h_tr & vde; ///vga blank output// assign blank = h_tr_h & vde; /////dual port RAM//// wire [7:0]Yw; wire [7:0]Cwr; wire [7:0]Cwb; dul_port_c1024 YYYR( .iDATA(YY[7:0]), .iHSYNC(TD_HS), .iHSYNCx2(blank), .Y_CLOCK(Ypix_clock), .Y_CLOCKx2(CLOCK), .oDATA(Yw[7:0]), .field(Field), .VS(TD_VS) ); dul_port_c1024 CBB( .iDATA(CCb[7:0]), .iHSYNC(TD_HS), .iHSYNCx2(blank), .Y_CLOCK(Ypix_clock), .Y_CLOCKx2(CLOCK), .oDATA(Cwb[7:0]), .field(Field), .VS(TD_VS) ); dul_port_c1024 CRR( .iDATA(CCr[7:0]), .iHSYNC(TD_HS), .iHSYNCx2(blank), .Y_CLOCK(Ypix_clock), .Y_CLOCKx2(CLOCK), .oDATA(Cwr[7:0]), .field(Field), .VS(TD_VS) ); /////YUV 4:4:4 output//// assign Y = (blank_h)?Yw :8'h10; assign Cr = (blank_h)?Cwr :8'h80; assign Cb = (blank_h)?Cwb :8'h80; endmodule1 Reply
i also don't understand these. Who can help us ?:-P
