10 years agoDE2 board GPIO Pin Output Voltage
Hi, I am using de2 board for a project, and I am using the pins from JP1(GPIO_0) as my output pins. So I have three output pins from that, and two of them having the correct voltage level which...
10 years agoTry modifying the project's pinout - re-assign one of the signals that works to the (apparently) non-working pin. If the problem moves with the signal - and the non-working pin starts working - then you have a coding (or possibly project constraints) problem. If the problem remains on the same pin then the device has probably been damaged.
Cheers, Alex
