16 years agoDE2 Audio Codec Programming
Hi, I am engg student.I are working on SOPC baesd speech to text conversion.I am confused with how to to program audio codec for Audio to Digital conversion for input from microphone and give it...
14 years ago --- Quote Start --- Hello, I am attaching a VHDL file which describes an interface to the Wolfson WM8731 Audio Codec chip located on the Altera DE1 and DE2 boards. This version just does output, but you can augment it to do input. For this you will have to read over the WM8731 datasheet. I have tested this on both the DE1 and DE2 boards. I hope you find it useful, but there is no warranty implied! Jim --- Quote End --- Maybe you could explain to newbie why the code is designed for a 24MHz clock. Doesn't both DE1 and DE2 have 50MHz and 27MHz clocks?
