17 years agoDE2 ADV7181 AD converter
Hi folks, I still work with Altera's DE2 board. This time I want to use AD converter. If I'm right, the output signal from DE2 DA converter is within a range 0 to 1,4V. Input signal range for ...
17 years ago --- Quote Start --- Are you sure? --- Quote End --- It's my understanding of the datasheet, but you should look yourself. The default automatic mode most likely isn't suited for your application, may a special configuration can work. The data format has to be decoded to select e. g. an Y stream. The Terasic demonstration examples are on the DE-2 CD shipped with the board, the CD content is also downloadable from terasic.com.
