17 years agoDE2 ADV7181 AD converter
Hi folks, I still work with Altera's DE2 board. This time I want to use AD converter. If I'm right, the output signal from DE2 DA converter is within a range 0 to 1,4V. Input signal range for ...
17 years agoThank you very much.
I just want to use both DA and AD converter for General Purpose. Not for video signals or similar. For example, I want to use the output from DA converter as the input for AD converter. Is it possible? You say that DA converter ADV7123 can be used in general purposes in contrast to AD converter ADV7181 which can be used only for video signals. Are you sure? Best Regards. :confused:
