17 years agoDE2 ADV7181 AD converter
Hi folks, I still work with Altera's DE2 board. This time I want to use AD converter. If I'm right, the output signal from DE2 DA converter is within a range 0 to 1,4V. Input signal range for ...
17 years agoThe application isn't clear from your post. The ADV7181 is dedicated to different kind of video signals and not suited for general ADC applications, I think. The ADC (Decoder) chip outputs time multiplexed digital video format. The ADV7123 in contrast has indidvidual RGB inputs and should be usable for GP DAC apllications as well. A back-to-back connection surely isn't possible. See the Terasic demonstration code as interface example.
