17 years agoDE2 AD converter
Hello folks,
I'm working on some project with two DE2 boards. I need to use D/A conversion on one board and send Analogue signal via wire to the second DE2 board. For D/A conversion I use tripple D/a converter on VGA. That's OK, I don't have a problem with this type of conversion.If I'm right, the output signal from DE2 DA converter is within a range 0 to 1,4V. Now, I need to receive this analogue signal on the second DE2 board and to convert it into digital form. You explained me in my previous threads that I can not use ADV7181 which is on DE2 board. Is there any other A/D converter on DE2 board? If there is not which A/D converter you suggest to me to use between two DE2 boards for analogue signal conversion? Thanx for your time and effort to answer me. Sorry if my explanation of the problem is not so clear. BojanNo RepliesBe the first to reply
