11 years agoDE2-70 Verilog SDRAM Controller
Hi All, Looking through the forums here I see that this question has been asked a lot, but I am struggling to actually find an answer to it. I have a DE2-70 development kit (Cyclone II EP2...
11 years ago1) create a new (empty) Qsys project
2) add the SDRAM Controller and configure it for your device organization and timing 3) connect the clock and reset 4) export the Avalon-MM Slave port and the Conduit for the SDRAM pins 5) generate the system 6) this is the end of using Qsys, forever 7) take the generated file (e.g. <qsys_project_name>/synthesis/submodules/sdram_0.v) and copy it wherever you like, modify it however you like, including removing the Avalon-MM should you care to. It is a small hurdle to get your hands on what otherwise is a relatively straightforward piece of Verilog (crafted by a Perl script) with correct organization and timing for your devices. Or, if you're OK with the GPL, check out the OpenCores project; but I'm not sure if that is more or less work as a starting point than the reference design you already found and are hesitant to use.
