17 years agoDE2-70 problem
I have DE2-70 with quartus/Nios 7.2, when I try to use a control panel the error "Fail to connect FPGA Board" appears. How to fix it?, please :)Hi,
I have DE2-70 with quartus/Nios 7.2, when I try to use a control panel the error "Fail to connect FPGA Board" appears. How to fix it?, please :)Hi Ctbram,
I had exactly the same problem as you described, but instead using 10.0 version. I would like to find out what you have to do in order to run the control_panel for the DE2-70. I just wanted to learn by following the users manual but ran into this problem. Can you share?
