11 years agoDE2-115 and Terasic High Speed AD/DA daughter card
Hi everyone, I am going to use the terasIC High Speed AD/DA daughter card (http://www.terasic.com.tw/cgi-bin/pa...english&no=278 (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=engl...
11 years agoHi Guys, Thank you all for clarifications and your time. I have worked with DE0-Nano and its ADC and because of its perfect User Guide there were not big problems and it was more simpler because of having NO HSMC connection.
One more point, I am using the AD/DA conversion card and it is different with THDB-ADA. What I have done so far, I have used pin assignment of sample project of terasic for DE2-115 board and AD/DA conversion card. Why I can not use the example project structure for my design because it is totally different with my purpose. In the terasic example they produce 1 Mhz and 10 Mhz sinusoidal signal and then transfer it through AD input to DA input. So far I only need to use AD input for my project to convert Analog signal to Digital and limit it somehow with FPGA. With thanks to Dave for many instructions I have below questions: 1- I have used Terasic example pin assignment for my design, Is it OK? I suppose it is ok because AD input pins are same? Isnt it? 2- There are many other signals which I do not know which one is necessary for a simple AD project like as clk : in std_logic; ADA_DCO : in std_logic; ADA_OE : out std_logic; ADA_OR : in std_logic; ADA_SPI_CS: out std_logic; AD_SCLK : inout std_logic; AD_SDIO : inout std_logic; FPGA_CLK_A_N: inout std_logic; FPGA_CLK_A_P: inout std_logic; but anyway I have assigned them as terasic sample project. 3- Which clock signal should I use? There are many clock signals like as clk, AD_SCLK, FPGA_CLK_A_N, FPGA_CLK_A_P, CLKIN1, CLKOUT0 Some questions maybe seem simple and funny for you guys but it is difficult for me. I am here to learn and hope you help me with your knowledge. Regards
