14 years agoDE2-115 and SRAM using SOPC (Qsys)
Hello Everyone, I need help pleeeeeeeeeeeeeese. I am trying to initlize the SRAM on the DE2 board using a C program, and I thought I will do this using SOPC. I've been told that t...
14 years ago --- Quote Start --- In case the provided sram mode doesn't meet your needs, use the template I attached. Rename the way you want, but remember to keep the *_hw.tcl suffix, which is mandatory, otherwise sopc builder won't find it. Change the parameters inside the file in order to match your sram device, then copy to altera\<version>\ip\user_components. --- Quote End --- Cris72, Where can I find the SRAM template that you mention? I'm trying to add a Cypress CY62146EV30 to my system and would like to create a component to match it. Alternatively, is there a repository for user created components where I can look for one for my memory? Thanks
