DE10-Nano JTAG
Is there any error message after you have executed "device_download_sof $d_path output_files/blink.sof"?
Can you check if the SOF file is actually in the folder?
Also, have you executed this command? get_service_paths device? Is there response from it? This is to determine is JTAG is connected properly.
Thank You.
Bruce
- phiho5 years ago
Hi Bruce,
Please read my posting again, I wrote in there:
Please note that the first part completed successfully, The amber D5 CONFIG LED did come up:
<quote>
Program the Intel® FPGA
To program the Intel FPGA device, we first need to get a service path to the device. We will assign that path to a variable called d_path by typing the following command:set d_path [lindex [get_service_paths device] 0 ]
Download the SOF file to the device by typing the following command:
The amber D5 CONFIG LED should be illuminated once the commands above complete
</quote>Regards,
phiho
- phiho5 years ago
Hi Bruce,
Please find appended below the transcript of Tcl System Console and Messages window.
Please note that blink.soft was successfully downloaded.
phiho
Here is the transcript of Tcl System Console:
% set d_path [lindex [get_service_paths device] 0 ]
/devices/5CSEBA6(.|ES)|5CSEMA6|..@2#USB-1#DE-SoC
% device_download_sof $d_path output_files/blink.sof% set jd_path [lindex [get_service_paths jtag_debug] 0]
% jtag_debug_loop $jd_path [list 1 2 4 8 15 16]
error: jtag_debug_loop: The path is not valid.
while executing
"jtag_debug_loop $jd_path [list 1 2 4 8 15 16]"
%and here are the messages:
Jan 18, 2021 7:38:17 AM com.altera.debug.core
SEVERE: wrong # args: should be "set varName ?newValue?"Jan 18, 2021 7:38:17 AM com.altera.debug.core
SEVERE: while executingJan 18, 2021 7:38:17 AM com.altera.debug.core
SEVERE: "set env(IntelliJ IDEA Educational Edition) "G:\\IntelliJ-Edu-2020.2.4\\bin;""Jan 18, 2021 7:38:17 AM com.altera.debug.core
INFO: Finished initializationJan 18, 2021 7:38:17 AM com.altera.debug.core
WARNING: Could not register IService packetJan 18, 2021 7:38:17 AM com.altera.debug.core
WARNING: A service named 'packet' is already registered.Jan 18, 2021 7:38:18 AM com.altera.debug.core
INFO: Finished discovering JTAG connectionsJan 18, 2021 7:38:18 AM com.altera.debug.core
WARNING: FPGA does not contain SystemConsole USB soft logic (signature 0x00)Jan 18, 2021 7:38:24 AM com.altera.debug.core
INFO: Finished discovering USB connectionsJan 18, 2021 7:38:24 AM com.altera.debug.core
INFO: Executing startup script G:\intel\fpga\lite\20.1\quartus\sopc_builder\system_console\scripts\system_console_rc.tclJan 18, 2021 7:38:24 AM com.altera.debug.core
WARNING: The script doesn't exist: C:\Users\Administrator\system_console\system_console_rc.tcl. You can customize System Console by creating one.Jan 18, 2021 7:38:24 AM com.altera.debug.core
SEVERE: wrong # args: should be "set varName ?newValue?"Jan 18, 2021 7:38:24 AM com.altera.debug.core
SEVERE: while executingJan 18, 2021 7:38:24 AM com.altera.debug.core
SEVERE: "set env(IntelliJ IDEA Educational Edition) "G:\\IntelliJ-Edu-2020.2.4\\bin;""Jan 18, 2021 7:39:41 AM com.altera.debug.core
INFO: Finished discovering JTAG connectionsJan 18, 2021 7:39:41 AM com.altera.debug.core
INFO: Auto linking 5CSEBA6(.|ES)|5CSEMA6|..@2#USB-1#DE-SoC to blink.sofJan 18, 2021 7:39:47 AM com.altera.debug.core
INFO: Finished discovering USB connectionsJan 18, 2021 7:41:32 AM com.altera.debug.core
SEVERE: jtag_debug_loop: The path is not valid.
