De10 lite
Hi.
the code have done seccessfullu compliation and i made the pin connection according to DE10-lite manual.
How did you assign your input pins? And did you program the DE10_LITE_Default.sof in DE10-Lite CD-ROM/Demonstrations/Default to verify function of the segments hardware?
- Zohar12 years ago
I don’t know how but I tried to run the sof file in the programmer two time in a row and then it worked.
But anyway thanks for your help- KianHinT_altera2 years ago
Hi Zohar,
Sorry for the delay in replying to this case, may I know whether the issue been resolved on your end or do you still require support on your end?
I saw there is a few youtube videos on programming the 7 segment led with de10 lite and also some cases where the 7 segment LED hardware fails on de10lite, does the example design in demo working?
Kian
Hi Zohar,
I will set this thread to community support since you mentioned that it is working and also thanks to our community people BXia and sstrell for their help in this case. If you have further questions or issues , do create a new thread and we will support you from there. Thanks for using Intel Forums.
Kian
