Zohar1
2 years agoDe10 lite
Hi. I’m trying to connect my pins to the seven segment display and every time I try to run the sof file the segment doesn’t go on. I checked the pins correct place.
sstrell
2 years agoWithout seeing any part of the design, there's really no way to know what's going on.
Is it getting programmed successfully?
- Zohar12 years ago
Hi.
the code have done seccessfullu compliation and i made the pin connection according to DE10-lite manual.
- BXia2 years ago
How did you assign your input pins? And did you program the DE10_LITE_Default.sof in DE10-Lite CD-ROM/Demonstrations/Default to verify function of the segments hardware?
- Zohar12 years ago
I don’t know how but I tried to run the sof file in the programmer two time in a row and then it worked.
But anyway thanks for your help
