SYiwe
7 years agoDDR4 calibration failed
Hi, I instantiate a EMIF IP core with DDR4 protocol in my design, modify memory timing parameters and board skew values. The DDR4 speed bin is 2400 and CL=16. After programming the device in EMIF ...
SYiwe
7 years agothanks.
In my current design, maximum skew within DQ/DM/DQS is 7.3ps, but both "maximum board skew within address/command bus" and "average delay difference between address/command and CK" exceed ±20 ps, I think that violate the guidelines and results in calibration error, although no errors in "Report DDR".
Is there any way to solve this problem except hardware update?
thanks, regards.
BoonT_Intel
7 years agoHi, Perhaps you can give it a try by reduce the interface frequency (to 533MHz) and see the calibration results.
