SYiwe
7 years agoDDR4 calibration failed
Hi, I instantiate a EMIF IP core with DDR4 protocol in my design, modify memory timing parameters and board skew values. The DDR4 speed bin is 2400 and CL=16. After programming the device in EMIF ...
BoonT_Intel
7 years agoYou can get it from here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/external-memory/emi_ip.pdf#page=170
SYiwe
7 years agoThank you.
I can see three calibration stages in table 45: Address and command, Read, Write.
Does the three stages process as "Address and command" first, then "Read", and "Write" last?
Thanks, regards.
