11 years agoDDR3L on cyclone V E (HMC)
Does the cyclone V (5CEFA4F23I7) support DDR3L in Hard Memory Controller ? Handbook says: The SDRAM controller offers the following features: Low-voltage 1.35V DDR3L and 1.2V DDR3U support. Bu...
11 years agoIt should be possible to operate all the HMC' s in a particular package at max speed. As previously stated, you only have one HMC on the device you mentioned. However, the larger devices, with two, should be able to operate both at max speed.
Cheers, Alex
